Stock SOHC 132 Hp
if you have dubs and subs get rid of them thats the best thing if it'schrome get rid of itget cf taillights and make some cf headlights,make cf doors,get rid of every interior part but the legal stuffand put in one light bucket seat.theres plenty more you can do
I used GTech and it said I'm getting 119 HP to the wheelswith a stock 1998 Neon Sport with a SOHCAutomatic. Best 1/4mile run was 15.9 @ 84mph. I've also used Digimoto hooked up Via my laptop to the OBD-2 port and it read my 1/4 time as between16 flat- 16.3.
I must admit I'm starting out by doing a neutral to first drop to get the RPM's up during launch, which helped take offquite a bit. Not recomended for normal use
I've also noticed letting off the gasafter it shifts into 3rd and repressing to about half way helps it gain power quicker for some odd reason rather than flooring it the whole way. Other runs I've done I've manually shifted it so 1st Gear runs to 52mph @ 5500RPM's2nd gear runs out to 92mph @ 5200 RPM's. My fastest Run's I've never used 3rd gear. The 5speed has to be wayflippin' faster if driven correctly. I'm sure mid 15's would be possible with a stock set up 5speed SOHC.
so with my bolt ons im prolly pushing like 115-120?
look at me Signature
or do bolt ons add hp to the tires?? well its gotta add some cuz its adding more to the crank which would eventually add to the tires am i right??
the horsepower at the wheels is just a fraction of the horsepower added to the crank
so yes you are gaining power to the wheels
and yea you are right with the 115-120 to the wheels
but probably leaning more towards 115
ORIGINAL: estneon
yeah i don't belive stock can do 119hp
well I did it with Gtech and at a local chassis dyno and it said 119 the chassis one was like 118, I'll upload my slip for ya guys when I get my scanner working.
no ifloor it too
maby it can be that good who knowa some might have been taken care of better than others if you got a 118hp stock than you probably took care of it or theres a mod you don't know
ORIGINAL: Slashwannabe
Some tranny repair man is gonna love you soon if you keep up them neutral drops
Better off brake torqueing..just hold the break down and the gas and let go of the break, gets you off quicker.
