Compression Readings
Old Jun 26, 2007 | 03:14 PM
pimpberetta's Avatar
pimpberetta
Default Compression Readings
Results:
Cold - Cyl. 1 2 3 4
187 186 195 185
Hot - Cyl. 1 2 3 4
182 185 194 184
With oil/hot- 1 2 3 4
194 201 205 195
How do these numbers stack up?
On a side note, the plugs are quite white in colour, assuming this means a lean condition, would O2 sensor(s) cause that?
Thanks
Old Jun 26, 2007 | 04:10 PM
spudsterier's Avatar
spudsterier
Default RE: Compression Readings
those dont sound too bad at all....
Old Jun 26, 2007 | 09:20 PM
Leonheart17240's Avatar
Leonheart17240
is that good to boost... because mine are right around there
Old Jun 27, 2007 | 12:15 AM
spudsterier
should be
Old Jun 27, 2007 | 01:46 AM
das2123's Avatar
das2123
ORIGINAL: Leonheart17240
One way to find out [sm=badbadbad.gif]
Old Jun 27, 2007 | 01:50 AM
winplet1971's Avatar
winplet1971
go or BLOW[sm=bomb.gif]
Old Jun 27, 2007 | 02:06 AM
Leonheart17240
then time to build fast motor...
Old Jun 27, 2007 | 01:50 PM
NYG's Avatar
NYG
ORIGINAL: pimpberetta
Results:
Cold - Cyl. 1 2 3 4
187 186 195 185
Hot - Cyl. 1 2 3 4
182 185 194 184
194 201 205 195
Thanks
Very Nice Numbers - How Many Miles do you have your Engine?? Is this with Stock Parts?
I rebuilt my engine with Factory Stock Parts and averaged only 170-180 Hot/Cold/Oil
How White are your Plugs and what kind of plugs are you running - it could be the Brand - I had a similiar issue with NGK Copper Plugs- ended up going back to Champion Copper to fix the White Color - I too tought it was my Sensors.
