(PIC) SNAPPED BOLT HELLLLLP!
Old Jun 26, 2007 | 05:40 PM
pssssst's Avatar
pssssst
Default (PIC) SNAPPED BOLT HELLLLLP!
okay, im about 2 seconds from insanity.... this car has been nothing but one giant problem after another since i got it 4 months ago and this is just adding fuel to the fire.... this is the front bolt to the lower front motor mount... the entire head of it snapped off and this is what im left with... can somebody pllllllllllllease help me figure a way to get this thing out??? i called a couple shops and they wont even touch it and the car is useless until it comes out... and it is in there extremely tight... any tips would be greatly apprecated thanks every1!
Old Jun 26, 2007 | 05:43 PM
spudsterier's Avatar
spudsterier
Default RE: (PIC) SNAPPED BOLT HELLLLLP!
is that the hole that the large iron piece bolts too???
where are the 2 studs that stick down for the mount bracket????
Old Jun 26, 2007 | 09:20 PM
pssssst's Avatar
pssssst
haha, u actually thought those lasted too!?!?!? lmao this car is a giant peice of corrosion and those welded bolts snapped out along with this peice of sh*t
Old Jun 26, 2007 | 10:28 PM
Beauff's Avatar
Beauff
Looks like someone needs to get their welding skills on. as far as that bolt gos you need to get a bolt extracter.
Old Jun 27, 2007 | 12:14 AM
neisg1's Avatar
neisg1
I've never had much luck with smaller sizes of bolt extractors, you could try laying a nut over the broken bolt and welding through the center onto the bolt, let it cool and try to remove the bolt,heat from welding may also loosen the rust.
