Oil Pressure ?!
Old Jun 27, 2007 | 02:06 AM
diggerdan911's Avatar
diggerdan911
Default Oil Pressure ?!
hey guys jus me ... i need a lil bit of help ? i have no clue Where to start and dont want to Rip my oil pump out if i dont have to ... when i start my car the Oil light Comes on ... the oil was jus changed 2 days ago ? and its full ? maybe 1/4 quart over ? well the light stays on but Engine Never over heats ? Good sign ? i think but the light stays on all the time Except when i Drive it... the light stays on in Reverse ... but when i have it in 1,2,3,4,5 light goes out if i have the gas pedal down 1/4 way but if i bring it up light comes on ... when car is at idle and rev it up a bit ....... or a lot light stays on all the time ? i dont know what to do ? i dont know where to start and im Confused ? it dosnt make any abnormal sounds it still has lots of pick up ... Sensor ? Slug build up ? oil pump ? Computer ? Gauge Cluster ? Faulty wiring ? any help would be most Greatful ! thanks alot
Old Jun 27, 2007 | 02:45 AM
winplet1971's Avatar
winplet1971
Default RE: Oil Pressure ?!
check oil sending unit
Old Jun 27, 2007 | 06:49 PM
diggerdan911
Wheres that Located ? it dosnt show me in the book i have ?!
Old Jun 27, 2007 | 10:04 PM
dcmcguy's Avatar
dcmcguy
its in the back of the motor towards the bottom, about 2/3 down... its only like an $8 part, also if its full of oil, its probobly junk, i just replaced one today actually...what happens, is the diaphram inside the sender wears out and it leaks oil all over and gives inaccurate readings
Old Jun 28, 2007 | 12:43 PM
racerx55's Avatar
racerx55
why the arrow i drew on doesnt show up untill you click the picture, i dont know [&:]
open that then u'll see it.
[IMG]local://upfiles/37714/F2E26ADA584241CFB9DEC93FE4D71542.jpg[/IMG]
