How to distingiush Crane Cam?
Old Jun 27, 2007 | 01:56 PM
NYG's Avatar
NYG
Default How to distingiush Crane Cam?
Ibought a set of Crane Cam off Ebay over a year ago - I just broke them out this week and is trying to determine if they are Crane and which Model Crane Cams I have for my DOHC Engine. Of Course I did not print out the EBay auction with the details.
How do you determine if they are Crane and which Model Crane - I am sure they are basic Cranes like a #10 or #12
If I put them on the table with my factory stock - they look very similiar in shape & Size
The only thing different about these cam are the color of the metal of the Cam - my factory stock are plain metal where these ones off Ebay have copper tint to portions of the cam
Any help - as Always - is appreciated!!
Old Jun 27, 2007 | 02:04 PM
spudsterier's Avatar
spudsterier
Default RE: How to distingiush Crane Cam?
on the end of the cam shafts....opposite the side the cam gears goes onto...there should be model numbers and serial numbers etched into them..
find the number and post it....then i can tell you what kind they are
Old Jun 27, 2007 | 04:14 PM
NYG's Avatar
NYG
Thanks Spudsterier,
I will check agian - don't recall anything etched - but will double check later this evening and post
Old Jun 28, 2007 | 12:08 AM
NYG's Avatar
NYG
Again you are right - they are hard to read - but some cleaning and a magnifing glass I was able to get these characters off of each CAM - I tried a google search on the numbers - but no luck
Crane CAM CHR 242-6 Intake 180-30-01
Crane CAM CHR 242-6 Exhaust 180-30-01
Old Jun 28, 2007 | 12:57 AM
spudsterier
sounds like crane #10's
#12's are CHR 246-8
Old Jun 28, 2007 | 02:52 AM
NYG's Avatar
NYG
Thanks Spud
If you had to guess - or if you know - what kind of gain off of a stock motor would the Cams add?? Ball Park!!
on a side note - how in the heck to you get the CAM Seals on??? I can get the Seals started - but I can not get them all the way seated - even tried to bolt on the Cam Gear - but it does not go back far enough to seat the Seals.
Old Jun 28, 2007 | 10:22 AM
spudsterier
i really have no idea what kind of gain you would look at..... i have a set of #14's that are going in my car and i would like to know what they would do me as well...
as for the cam seal:
i use a few different methods that i use......if you have a big enough socket, you can try to put it over the end of the cam and get it to rest on the seal...then just lightly tap the socket with a hamer...
or
use a center punch and tap the seal into place
either one work fine
Old Jun 28, 2007 | 11:17 AM
NYG's Avatar
NYG
Thanks Spudsterier
I don't have a socket deep enough - I tried tapping it on - I got it on over half way - let it sit over night and try again this afternoon.
My Next question I was going to ask was there a different cam seal for the Crane - My New seals fits my original cams - they were a tight fit - but are alot easier then these Crane's
Might try to sneak over to a Dyna next week and see what my stock little baby is going to do
Old Jun 28, 2007 | 04:13 PM
spudsterier
as far as i know the seals should be the same for the stocks and the cranes.....maybe try to put a little lube on the inside of the seal
