Read: Instrument cluster
Old Jun 28, 2007 | 03:59 AM
wildfan1833's Avatar
wildfan1833
Default Read: Instrument cluster
I have a 1996 neon. My instrument cluster works from time to time. I was told that my cluster was bad and I need to get a different one. What do you think?
Old Jun 28, 2007 | 04:00 AM
mulletman11's Avatar
mulletman11
Default RE: Read: Instrument cluster
i think the same problem happened to me, and i got a new one and it was fixed. i was a mazed, but that really was it. hey howd you know i got rid of my old one anyway??
Old Jun 28, 2007 | 04:06 AM
neoncrazy101's Avatar
neoncrazy101
which things from the cluster only work partly? could just need to be re-soldered. its a common problem...
Old Jun 28, 2007 | 04:18 AM
wildfan1833
everything on the cluster dosen't work. If and when it works it will work for about 5min at the max.
Old Jun 28, 2007 | 04:21 AM
neoncrazy101
just replacing the cluster may or may not fix it. or it may fix it for alittle while but then it will come back...trust me happened with me before i knew about the resoldering fix... heres a how-to on how to do it and just try it first and then if it doesn't work then you can try replacing the cluster.
https://dodgeforum.com/m_179505/tm.htm
