is it Possible to mount 2.2 Turbo setup on 2.0 SOHC Neon Engine?
Old Jun 29, 2007 | 01:52 AM
prplhaze's Avatar
prplhaze
Default RE: is it Possible to mount 2.2 Turbo setup on 2.0 SOHC Neon Engine?
ORIGINAL: BadBrads97Neon
Go with the SRT turbo. Alot less than the Hahn kit and bolts right up. Not saying Hahn doesnt bolt right up, but for the same amount of power I could save almost 2 grand. My $.02
When you say bolts right up, do you mean the srt-4 engine bolts right up to the neon chassis, transmission, axles, all the same.? Or do you mean the srt-4 turbo system bolts right to the 2.0 engine.? Which I know the dohc and sohc have different exhaust manifolds, so which does it bolt too.? I'd love to find a smashed srt-4 in a junkyard and pull parts to make my beast go faster...
Old Jun 29, 2007 | 01:57 AM
95neonriceeater's Avatar
95neonriceeater
the SRT turbo manifold can bolt right onto the DOHC head
look at spuds
Old Jun 29, 2007 | 02:01 AM
estneon's Avatar
estneon
there are better custom systems that can make anyone drool taking 20-40psi and shoving it on a neon would be fun.
Old Jun 29, 2007 | 02:03 AM
95neonriceeater
to handle 20-40 psi you have to do A LOT of work
everything that spud is doing and maybe more
i dont even think a neon can handle 40...
but if it can then do it!
Old Jun 29, 2007 | 02:17 AM
estneon's Avatar
estneon
im shooting for 15-20 myself but i will have a reenforced engine like spud so i can't wait.mine will be a one of a kind set up.me so happy!!!
Old Jun 29, 2007 | 10:43 AM
spudsterier's Avatar
spudsterier
the turbo...not motor
the srt4 turbo is capable of pushing 20psi.....so thats what im gonna run...
my pistons and rods are good for 30psi AND a 300 shot of notrous......simultaniously
the motors can handle plenty of power if built right......but it costs plenty money.....
so far i have about $2100 in just the block.....then just under $1000 in the head.....and a little over $1000 in the turbo kit.......plus plenty of other misc parts....
you can get a wrecked srt4 to get most of the turbo parts.....but it owuld be alot cheaper just to buy them individually
Old Jun 29, 2007 | 11:22 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
True, but then you could sell off all the other stuff to get some money back.
Old Jun 29, 2007 | 11:34 AM
spudsterier
yeah but if you gonna do that then why spend all that extra money in the first place
well, besides to sell me the seats
Old Jun 30, 2007 | 03:47 PM
prplhaze's Avatar
prplhaze
So...can you take a dohc head and put it on a sohc block.? I know you would have to change the pcm...but Im not sure if the heads are compatible....[sm=badidea.gif]..?
Old Jun 30, 2007 | 04:41 PM
estneon's Avatar
estneon
yes you can look in the 1st gen Common Thread Topics and it is a good idea because it lowers compression witch is good for a turbo.oh and they are compatible you would also need a new timing belt
