MTX Fluid
Old Jun 28, 2007 | 07:08 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Default MTX Fluid
Ok so i have this written down somewhere but Im at work right now and need to stop on the way home to get some things and just wanted to ask. What kind of fluid/oil do I need to get for my mtx to fill it up as much as it needs to? Also how much do I need to buy? Im starting my swap tonight YAY!!!!! and this is pretty much the last thing I need to get. Any help would be greatly appreciated! Thanks
Old Jun 28, 2007 | 08:14 PM
spudsterier's Avatar
spudsterier
Default RE: MTX Fluid
mopar atf+4
need a few quarts of it, but im not sure how much
Old Jun 28, 2007 | 08:53 PM
BadBrads97Neon
Ok cause I have heard about using this "Redline" stuff too. So I was just wanting to know.
Old Jun 29, 2007 | 12:49 AM
NYG's Avatar
NYG
ORIGINAL: BadBrads97Neon
I use the RedLine MTL - its a SAE 70W80 API GL-4 Gear Oil.
My Shop Manual Calls for 3 to 4 Qts
If go to Redline website you can submit a request for recommended Lube - be sure to elaborate on how you drive your car.
Not trying to knock the ATF+4 which is recommended by the Factory - but I had issues with the ATF+4 vaporizing and/or Foaming on me.
Also I found most of my competitors running Redline Oil and Lube.
Old Jun 29, 2007 | 03:18 AM
neoncrazy101's Avatar
neoncrazy101
what about the fluid at like Autozone? aka Pennzoil gearlube and such.
Old Jun 29, 2007 | 03:24 AM
NYG's Avatar
NYG
ORIGINAL: neoncrazy101
I have not tried those - I originally started off with visiting the Dodge Dealer to buy tranny Lube - then after having issues with foaming and vaporizing and noticing my competition used RedLine - I swapped over.
Originally I used Amsoil for my Engine Oil and ATF for the Tranny - but found Redline has a complete line of products that meet my needs
Old Jun 29, 2007 | 10:46 AM
spudsterier
i have always just used 80/90 gear lube
Old Jun 29, 2007 | 11:20 AM
racerx55's Avatar
racerx55
penzoil synchromesh
my transmission hold together on it, every time i use 80w90 i lose power and the trans locks up or blows apartin a 20 lap race.
Old Jun 29, 2007 | 11:33 AM
spudsterier
they usually lasted me about 100,000 miles on 80/90....but i always drove them really really hard
Old Jul 4, 2007 | 08:41 PM
Aerorat's Avatar
Aerorat
that is what I used in my trans that was with my 2.0 and I also used it with the trans that came with the srt4 2.4. And my hanes and chilton both say to fill it up just to the plug where you put it in. In which is on the front diver side of the car
