Proportioning Valve interchangeability question
Old Jul 3, 2007 | 03:27 PM
MaverickH1's Avatar
MaverickH1
Default Proportioning Valve interchangeability question
Will the two prop valves from a '95 non-ABS, 14" disc front/drum rear work on a '95 non-ABS, 13" disc front/drum rear?
I assume there are two possibilities:
1) No they are not interchangeable.
2) The threads will fit, but the prop valves will send more pressure to the rear brakes than it should, and as a result will wear down the rear shoes quicker.
What say you?
Old Jul 3, 2007 | 05:31 PM
racerx55's Avatar
racerx55
Default RE: Proportioning Valve interchangeability question
i dont see why it wouldt work.
Old Jul 25, 2011 | 08:15 PM
robsmy5606.rm@gmail.com's Avatar
U have a cracked o ring at bottom stem
