more fuel
Old Jul 7, 2007 | 11:26 PM
Leonheart17240's Avatar
Leonheart17240
Default more fuel
hey what happins if you put a bigger injector in without other moter work???
Old Jul 8, 2007 | 05:53 AM
racerx55's Avatar
racerx55
Default RE: more fuel
would run rich of course.
Old Jul 8, 2007 | 10:00 AM
spudsterier's Avatar
spudsterier
it can cause your motor to choke on fuel since its getting too much
Old Jul 8, 2007 | 01:42 PM
Leonheart17240
shouldnt the computer read that its rich and lean it back out?
Old Jul 8, 2007 | 02:51 PM
mmench's Avatar
mmench
well i was just about to make a post on the same topic when i saw this one. i just put in a set of srt4 injectors to use when i put my turbo on next week. wheni start it up now it stumbles all over its self and in the upper rpm's it breaks down pretty badd. does anybody have a suggestion on what is should do.. should i take them out and get a set of like 28pound injectors or will the turbo even it out.
Old Jul 8, 2007 | 03:25 PM
spudsterier
the injectors will work fine with the turbo because when you hook up the fuel regulator, you cna just lower the fuel pressure a bit to even it out.....but for the mean time, i would take them out....
like i said, your motor can choke from too much fuel
Old Jul 8, 2007 | 03:43 PM
Leonheart17240
ya i put in a set of 32 lb in, stumbles on start up, and in 3rd at 6500 it sounds like its hitin the rev limiter... not good
Old Jul 8, 2007 | 11:05 PM
mmench's Avatar
mmench
yea im goin to take them out until i get the turbo on. it pulled good in the mid rpm's but it is just dumping fuel out the exhaust and at an idle or high rpms its rough.
Old Jul 9, 2007 | 05:13 AM
racerx55's Avatar
racerx55
you dont need bigger injectors untill your engine is higly modified and they cant put enough fuel to it anymore. usually the fuel pump is what cant keep up before the injectors are at 100%
why so many people buy bigger injectors ill never know.
i have 550cc injectors in my talon (100cc bigger than stock) and its making well over 350HP.
when you get there its time to go up. untill then, or untill its got some boost, use what it has, theyre capable of more fuel then that poor little motor will ever need unless its got a turbo on it.
Old Jul 9, 2007 | 07:21 AM
spudsterier
if you get rid of your stock fuel pressure regulator then the stock injectors will be fine...
with 8 pounds of boost my stock injectors worked just fine....
