I NEED HELLLLLLLLLLLLLLLLLLLLLLLP!!!!!
wow, it has been 2 weeks now since this bolt snapped when i was trying to simply change my front lower motor mount... i have tried to drill into it to use an easy out and this bolt is not even drillable apperantly.... wore down at least 3 drill bits i had and didnt even starta hole..... next, i tried to weld a nut on the end to wrench it out... but the bolt broke just so its basically a stub sticking out and i cant even get a nut started to thread on so the weld wont hold for nothing.... i seriously am baffled and have no clue what to do next.... please somebody tell me what the next route to go would be... thanks to all who post
thanks for the suggestion... but i dont have a plasma cutter and i would nevercut a section out of the frame to remove a bolt... theres gotta be another way...
thanks spud, should i just drill a pilot hole and try an easy out type thing? or get a 7/16 bit and drill the entire thing out???
Trending Topics
I would try the pilot hole with an E-Z out, and use heat (mapp gas works best) lots of heat! Get that stub nice and hot after you drill it,but before you put the E-Z out in. you dont want to heat up the E-Z out with direct heat.
ORIGINAL: pssssst
its not the frame, its the core support, these cars dont have frames, you can weld to that all day, my race car is all welded up there.
