Avenger head conversion
Old Jul 11, 2007 | 03:37 PM
neon_leon's Avatar
neon_leon
Default Avenger head conversion
This may be dumb Idk i just seen this and thought of it but has anyone attempted or actualy taken a dodge avenger head DOHC head and put it on a neon to were the exhaust is on the front so if your turbo it then it would be right there and easy to get to? Is it possible? Im thinking about trying it cause the cams are still on the same side as our neon motors is just thought it would be different to try in the neon. I swapped to a 2.4 and I think it would be a good idea having my turbo easy to get to and running the piping. let me know thanks.
[IMG]local://upfiles/58307/E7FBBF075A1D47FDBD9832F7410D3BEF.jpg[/IMG]
Old Jul 11, 2007 | 04:02 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Avenger head conversion
I think you would have to get the whole motor because the oil and coolant ports might not line up...
Old Jul 11, 2007 | 07:16 PM
AMM's Avatar
AMM
i believe mike crawfords hot rod car has that setup in it............. or it did. it can be done but why would u want to???
Old Jul 12, 2007 | 01:06 AM
racerx55's Avatar
racerx55
read up on your engines, its the same bottom, same head casting with reversed airflow direction, and they LOST power when they did it.
its the same thing as the mitsu eclipse motor.
it will work but good luck finding room in a neon
Old Jul 12, 2007 | 08:39 AM
das2123's Avatar
das2123
ORIGINAL: racerx55
Thats one of the biggest obstacles, but nothing a BFH can't handle
Old Jul 15, 2007 | 03:34 PM
neon_leon's Avatar
neon_leon
I was just thing of easier work getting to the turbo on the front tryin to do it with the turbo in the rear is a pain in the butt.
Old Jul 15, 2007 | 04:45 PM
das2123's Avatar
das2123
ORIGINAL: neon_leon
I figured that, but if it were a simple swap or even a doable swap, it would have been done already.
Old Jul 16, 2007 | 06:40 PM
neon_leon's Avatar
neon_leon
well Im thinking bout tryin it on one of my other neons. Ill post how it goes when the time comes any new news bout doing it let me know all info is helpfull.
