Front Wheel Bearing Replacement
Old Jul 12, 2007 | 01:19 PM
professionalpirate's Avatar
professionalpirate
Default Front Wheel Bearing Replacement
I'm trying to do a wheel bearing replacement on a '97 Dodge Neon 2.0 SOHC. Manual has nothing on it. The guy at the auto parts store said I needed a 10ton press to remove the bearing and that sounded a little strange to me. Any information would be helpful.
Old Jul 12, 2007 | 01:27 PM
spudsterier's Avatar
spudsterier
Default RE: Front Wheel Bearing Replacement
the wheel bearing is pressed into the hub assembly.....you will have to remove the whole spindel assembly and bring it into a shop to have the old one pressed out and a new one pressed in
Old Jul 12, 2007 | 04:15 PM
professionalpirate
Thanks. So, if I have a press available to me, how do I go about doing it myself?
Old Jul 12, 2007 | 07:11 PM
Aerorat's Avatar
Aerorat
Place a socket on the side of the lug nuts and a 3" piece of steel tubing on the other to press the bearing into
