Acceleration trouble!!!
Old Jul 15, 2007 | 05:46 PM
neon527's Avatar
neon527
Default Acceleration trouble!!!
97 SOHC MTX
when iput the pedeal to the floor it dosent want to accelerate fast, it boggles ~n~ if i press on da pedal 1/4 to /1/2 way down it will pick up faster, any reason y its doin this is it designed that way or do i have a air/fuel mixture problem or wat?
Old Jul 16, 2007 | 09:27 PM
neon527's Avatar
neon527
Default RE: Acceleration trouble!!!
im guessin nobody else has this problem or nobody has an answer?...lol..
Old Jul 17, 2007 | 02:58 AM
Slashwannabe's Avatar
Slashwannabe
mine seems to have more power at half throttle on take offtoo dunno why.
Old Jul 17, 2007 | 01:45 PM
boxerjl2's Avatar
boxerjl2
the only time my pedal is pressed its pedal to the medal so thats when i go the fastest
Old Jul 17, 2007 | 03:14 PM
Aerorat's Avatar
Aerorat
Check your air filter and spark plugs make sure both are clean.
Old Jul 17, 2007 | 03:28 PM
Slashwannabe
ORIGINAL: Aerorat
I take it you don't have that problem : )
Old Jul 17, 2007 | 09:25 PM
neon527's Avatar
neon527
everything is perfect!!! i dunno wats up im so confused???
Old Jul 17, 2007 | 09:57 PM
Aerorat's Avatar
Aerorat
ORIGINAL: Slashwannabe
ORIGINAL: Aerorat
Not since I put in the srt 4 engine and trans
Old Jul 18, 2007 | 02:17 AM
Slashwannabe
lol I suppose.
When my car is running for only 15 minutes it hauls *** off the line after about 30 minutes it loses power but still has decent power.
Old Jul 18, 2007 | 03:06 PM
66furythree's Avatar
66furythree
Check your Throttle Position Sensor and wiring. Fuel pump, filter all related to WOT (Wide Open Throttle) Lag.
