well my other post went to hell and no one helped
Old Jul 17, 2007 | 02:04 PM
boxerjl2's Avatar
boxerjl2
Default RE: well my other post went to hell and no one helped
so the passenger side tire is the one that the tranny spins right
so i turn on the car (once its jacked up) and put it into 1st?? its not gonna take off or anything right??
Old Jul 17, 2007 | 02:06 PM
boxerjl2's Avatar
boxerjl2
the wires have alot of slack but ill try it
Old Jul 17, 2007 | 03:37 PM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: boxerjl2
Pull your ebrake and put some sort of block or wood behind the tires and use jack stands shouldnt go anywhere then.
Old Jul 17, 2007 | 03:59 PM
boxerjl2's Avatar
boxerjl2
well then wouldnt stall and shut off? cuz ive killed it before like that cuz i wasnt thinking and went to go foward with e brake but i guess i let off of the clutch to soon
Old Jul 18, 2007 | 01:48 AM
racerx55's Avatar
racerx55
i thought you had a damn automatic, dammit
now i gotta start over.
arg [:@]
Old Jul 18, 2007 | 10:18 AM
boxerjl2's Avatar
boxerjl2
lol yeah right i hate autos[:@]
start over with what???
Old Jul 18, 2007 | 01:03 PM
spudsterier's Avatar
spudsterier
the vss gear on a manual runs off of a ring gear on one of the tranny drive gears........if you feel like that gear is messed up then you have to take the tranny apart in order to get to it
Old Jul 18, 2007 | 04:02 PM
boxerjl2's Avatar
boxerjl2
that sucks,
is it a hard job???
if i take it apart doi have to getthe transmisionrelubed or anything?? and once ive opened it up what do i do just tighten something up or what??
am i the only one on the forum that has ever had this problem??
Old Jul 18, 2007 | 04:06 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: boxerjl2
well when i put my finger inside the tranny i feal a plastic (fealing) ferris weel like thing which i figurd was the gear cuz thats the only thing there around were you put the vss in the tranny and it was all loose and wobbly
looks like you found the problem
Old Jul 18, 2007 | 04:58 PM
spudsterier
ORIGINAL: boxerjl2
from the sound of it......yes
when you remove the tranny from the car, there will be about 15-20 bolts that hold the main case to the bell housing......after you remove the bolts you can take a hammer and lightly hit all the way around the case until you separate the case from the bell housing......after that you will have to pull out the main gear and remove the vss drive gear and get it replaced
hardest part is putting the main case and bell housing together....there are 4 shifting fork rods in there that can give you alot of problems and need to be adjusted just right...otherwise, the speedo not working would of been the least of your problem
and no i dont know where you can get one of those gears from
