Battery/ the biggest one I can?!
ORIGINAL: Montey21
what's the biggest battery I can put in my neon? Is there a danger of frying the computer or anything else? I use it as a mobile field office. Thanks for any help
ORIGINAL: boxerjl2
lol so do you just routinely stomp the **** out of this guy or what..lol
how do you run your alt to power batterys in trunk?do youjust extend wires as if you wereputting your car battery in the trunk ? so is your alt powering 3 batteries or is one of the two powering your car also?
But now back to the batteries I am using 2ga audio power cable with fine thread copper strans. The finer the better. I have it running throught the body. not under it.then under the hood I have a distribution block.Then it goes to the start, alternator, and powers the rest of the car
ORIGINAL: Jr. Mechanic
Get a Deep cycle marine battery, you could run your lap top off that for two days and it wouldnt go dead, but you will have to put it in the trunk. Remember you cant have two batterys hooked up together because you will need a cross over from the positive the the negative on the other battery which will make a 24 volt system
And, no matter what battery you get, as long as it is 12 volt, it will not fry anything because a battery only puts out what is used, you could have a battery with a million cranking amps but still only draw a hundred when you start it.
ORIGINAL: Aerorat
how to get your *** smoked
ORIGINAL: 66furythree
Damn your smart, wish I knew how to do that. All my daddy taught me was how to smoke.
PS there is a 427 Ford side oiler under that motor box cover.
[IMG]local://upfiles/56817/3B28E70829E54E8896C5AB06C332AC65.jpg[/IMG]
ORIGINAL: Captain Squalus
Hell I'll race your Peon with my 1967 17'Century Resoter boat then you will know what it's like to get smoked
ORIGINAL: Aerorat
1 decentbattery should be enough....lol Maybe just upgrade the inverter.
I ran my laptop for 6 hours last night off my inverter in my Neon withoutEngine running,its a 350watt Ralley Inverterand it can handle charging a cell phone and powering 2 computers. Mine and my brothers laptop eats about 90watts each and it will run both fine. Allthough I dohave a stockstereo system upgraded with Wal Mart Durabrand tweeters....lol (wow I said upgraded and Wal Mart in the same sentance!) Pretty much no powerdemand from the stereo..ahahaha.
My $10 Junk yardIntersate battery lasts long enough for when a person needs to pull over and get free internet.
ORIGINAL: Aerorat
I personallythink the Ford will win that racein who gets "Smoked out"first. Pretty much a glorified mosquito killer
.j/k : )
why do i always here the term Peon?
Captain Squalusdo you have a neon??? well you prolly do
just wandering cuz you dont have a photo gallery
