wiring harness
Old Jul 22, 2007 | 01:58 PM
Aerorat's Avatar
Aerorat
Default RE: wiring harness
Had to replace my wife's pcm in her 2001 neon rt and it was $875.00. Thank goodness it was under warranty. It had 15 miles before the warranty was expired
Old Jul 22, 2007 | 03:40 PM
rrwertz's Avatar
rrwertz
I may have one. I'll check this afternoon.
Old Jul 24, 2007 | 11:33 AM
DAGS's Avatar
DAGS
would any other year wire harness be the same?
Old Jul 24, 2007 | 11:37 AM
das2123's Avatar
das2123
97-99 should swap in fine. You may have to splice in some sensors if you use a 98-99.
Old Jul 24, 2007 | 12:16 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Well, I used a 98 harness in my 97, and I dont recommend it. I had to splice the injector harness, map sensor, vss, alternator, starter, tb sensor, and a couple other ones. It really sucked. I would suggest finding one from a 96 or a 97, little to no spliceing there.
Old Jul 24, 2007 | 12:52 PM
spudsterier's Avatar
spudsterier
ive said this before but here it is again....when it comes to engine wireing harnesses,
95 and 96 will swap between the 2 years, but will not swap between 98 and 99
97 is unique to that year and is kinda a cross-breed between the 95 style plugs and 98 style plugs
98 and 99 will swap between the 2 years, but will not swap between 95 and 96
when i say they wont swap, its more or less that they wont swap without doing some splicing
Old Jul 24, 2007 | 12:59 PM
das2123's Avatar
das2123
^^Just added to the FAQ with props given.
Old Jul 24, 2007 | 01:06 PM
spudsterier
well thank you
