steering wheel removal gone bad?
Old Jul 24, 2007 | 11:28 PM
neoncrazy101's Avatar
neoncrazy101
Default steering wheel removal gone bad?
aye well i got the puller from autozone and as i was pulling it was REALLY hard. and then all the sudden something snapped. the threads in the wheel that the two bolts go into, got completly stripped. so now i can use a puller to get it off. any idea's on how i should try and get it off now?
Old Jul 24, 2007 | 11:43 PM
kris95neonspt's Avatar
kris95neonspt
Default RE: steering wheel removal gone bad?
I don't think you want to do it this way but i had tooka dremal tool and cut the wheel off. Or you can also just replace the steering colium with another one.
Old Jul 24, 2007 | 11:49 PM
neoncrazy101
i'm swapping steering wheels though or i wanted to. from my '97 wheel to my '95 wheel. and it happened on my '95.
Old Jul 25, 2007 | 12:46 AM
kris95neonspt
You can just change entire steering coliums then. i dunno if it makes a difference but the horn buttons are in a different location in 95. 96-99 are in the center and 95's are on the sides.
Old Jul 25, 2007 | 01:08 AM
racerx55's Avatar
racerx55
ill give you one to try, one, you need an old nut from another car, screw it on the center shaft till its FLUSH with the shaft., pull as hard as you can on your steering wheel, and have another person hit the end of the shaft with a hammer HARD. it will usually knock the wheel loose, the nut will stop it from flying off and hitting you in the face.
you gotta be carefull you dont beat up the threads on the shaft, thats why you use a different nut to beat on.
Old Jul 25, 2007 | 01:13 AM
racerx55's Avatar
racerx55
BTW use a big hammer, not a little girly nail tapping hammer, something heavy that hits hard.
one good hard hit should do the trick
Old Jul 25, 2007 | 02:44 AM
boxerjl2's Avatar
boxerjl2
why are you changing it ??? is it differant looking or are you just bored and need a project
Old Jul 25, 2007 | 04:46 AM
Dr_KY's Avatar
Dr_KY
ORIGINAL: racerx55
I was going to suggest the same thing man. I think I have only used a puller on a steering wheel once in my life, I find a nice dead blow hammer solves the problem. and leaves no damage or marks. I have this one from Harbour Freight..
At $6.99 no tool box should be without one.
http://www.harborfreight.com/cpi/cta...temnumber=1309
Old Jul 25, 2007 | 07:53 AM
neoncrazy101
ORIGINAL: boxerjl2
they do look different. but its because i think the owner before me really liked to grip his wheel cause the current wheel is crap. like literally. at 9 o'clock and 3 o'clock its worned down to the metal.
Old Jul 25, 2007 | 08:35 AM
das2123's Avatar
das2123
Drill and retap the threads. You will then have to find 2 screws to use, as the ones that Autozone provides won't be of any use now. We had to do that on my nephews RSX when we swapped dashes.
