Aftermarket water temp gauge
Old Jul 25, 2007 | 11:48 AM
protivakid's Avatar
protivakid
Default Aftermarket water temp gauge
I was considering getting an aftermarket water temp gauge because I want a gauge with actual numbers, not that idiot gauge on the main cluster. How hard would this be to install? I have seen one before and it seems to be hooked to a metal hose and then to a temp sensor on the end, assuming that’s how it’s set up, where do I put this temp sensor?
Old Jul 25, 2007 | 12:40 PM
boxerjl2's Avatar
boxerjl2
Default RE: Aftermarket water temp gauge
i would thnk that the original temp guage would have wires to hook up the after market one to were you wouldnt have to do anything else but i dont know much about it
Old Jul 25, 2007 | 12:57 PM
das2123's Avatar
das2123
https://dodgeforum.com/m_495938/tm.htm
Old Jul 25, 2007 | 07:19 PM
Dr_KY's Avatar
Dr_KY
Get a 'manual' gauage not an electronic one. Just jam it into the block in one of the water jackets and you willbe fine.
