OMFG ***Comeon, I could Really, Really use some help***
Old Jul 26, 2007 | 04:29 PM
spudsterier's Avatar
spudsterier
Default RE: OMFG
well...ya got me
Old Jul 27, 2007 | 10:45 AM
NYG's Avatar
NYG
Default RE: OMFG
Do you have a Good ODB2 Tester?? Like a SnapOn MT2500 - They are usually on Ebay for a couple hundred bucks
It will allow you to go to each sensor and see what it is doing and how it is responding and while you are cranking over you can check for Crank Sensor and Cam Sensors
My Crank Sensor was bad and gave no codes - but while cranking over the engine - I was able to see via the MT2500 that the Sensor worked but was getting no reading from the Crank. Once I replaced the Crank Sensor - she cranked right up!
Old Jul 28, 2007 | 12:10 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: OMFG
I just have a regular actron scanner, it still tells me alot, just nothing I need to know[:@]
I dont know what to do to this car, das, which would cut out if the crank sensor was bad, the 12v green orange wire or the pcm wires?
Old Jul 28, 2007 | 12:41 PM
prplhaze's Avatar
prplhaze
Default RE: OMFG
I woulda thrown a new crank sensor in long ago...after all your going thru.
