swap?PLZ look
Old Jul 25, 2007 | 08:35 PM
jakedlee16's Avatar
jakedlee16
Default swap?PLZ look
could i build a nice DOHC and swap it easily into my 95 SOHC ? i dont see why i couldnt .. also how much would it cost and could i use two cams of of SOHCS for the cam gears?
Old Jul 25, 2007 | 09:14 PM
spudsterier's Avatar
spudsterier
Default RE: swap?PLZ look
1st things 1st.......sohc's and cam gears will NOT work on a dohc......the cams are completely different..the cam gears are the same size, but the timing marks are in different locations...
you can put a dohc in a 95 sohc....but,
you will either have to find a 95 dohc pcm....or....find an engine bay wiring harness from a 96-99 and swap it into your car...(isnt as hard as it sounds)
Old Jul 25, 2007 | 09:16 PM
das2123's Avatar
das2123
ORIGINAL: jakedlee16
Yes you can. Or you can just swap a DOHC head onto your block and be happy.
Depends on what you spend on it. Shop around to get good prices.
No.
