My Neon
Old Jul 26, 2007 | 10:16 PM
spudsterier's Avatar
spudsterier
Default RE: My Neon
none of the srt4 body parts are interhangable with the 95-99 neons....
it isnt too bad to build up a neon and can easily put out plenty of horsepower
Old Jul 27, 2007 | 11:31 PM
96dodgeneonbuild's Avatar
96dodgeneonbuild
Default RE: My Neon
whats the range of power can i get out of the 2 liter?
cuz i wanna build
Old Jul 27, 2007 | 11:34 PM
96dodgeneonbuild
Default RE: My Neon
where or how do you get to the governer on my neon?
and can you get a KnN cold air intake for this year of car?
Old Jul 28, 2007 | 01:39 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: My Neon
the k&n intake built for the neon is only a warm air intake
the only real cold air intake is either the iceman or if you build a custom 3.0 intake
the iceman is not being sold under the "iceman" name
but for the exact same product i think that mopar took it over
it's 300 dollars and if you dont want to build the 3.0 intake its the best you're going to get
Old Jul 28, 2007 | 09:23 AM
spudsterier
Default RE: My Neon
to remove the govoner you will have to remove the speed sensor....therefor you will also loose your speedometer.....
you can get pretty good power out of the 2.0l.....it just takes a bit of money and alot of time
Old Jul 29, 2007 | 01:21 PM
96dodgeneonbuild
Default RE: My Neon
so the iceman intake is not the manifold is it? cuz i was talking about the actually air filter housing and how is it warm air? it doesnt reach all the way up to be cold air?
and thats cool about the power but i was wanting a hp range like ... what 200 or more?? or more then 300 ??? you know???
and there should be a way to remove the governer without loosing my speedometer?
and if you do can you hook up a aftermarket speedometer?
Old Jul 29, 2007 | 02:08 PM
95neonriceeater
Default RE: My Neon
there aren't aftermarket speedometers for our neons
but if you do find one post it up
the iceman is the intake but iceman is discontinued
it places the filter next to the transmission
any filter in the rear of the engine is a warm air intake
it's getting hot air from the exhaust manifold
the only ones that move to next to the transmission to make it a true cold air intake is the iceman (if someone is selling it otherwise discontinued) mopar (the iceman now) or the 3.0
if you want an intake manifold there is the Indy intake manifold
there is also a guy on here building custom intake manifolds that are pretty BA and give a ton of power
