Mopar Performance Motor Mount.. bushings needed??
Old Jul 26, 2007 | 02:16 AM
boxerjl2's Avatar
boxerjl2
Default Mopar Performance Motor Mount.. bushings needed??
IfI Purchase The Mopar Performance Motor Mount Do i need to get the prothane front motor mount bushings also???
im getting them from modern unless anyone know of some where cheeper
howell is like 70.00 so its modern or somewere else
Old Jul 26, 2007 | 02:19 AM
boxerjl2's Avatar
boxerjl2
Default RE: Mopar Performance Motor Mount.. bushings needed??
is it better to just go to a junk yard and get the motor mount?? or is it worth it for the moparmotor mount??
Old Jul 26, 2007 | 02:21 AM
boxerjl2's Avatar
boxerjl2
and does the motor mount come with the bolts needed???
ryleynoyes's Avatar
ryleynoyes
no, the mopar is better than inserts
http://pages.cthome.net/rader/performance.html
Old Jul 26, 2007 | 02:26 AM
ryleynoyes's Avatar
ryleynoyes
i take that back, you CAN use the inserts with the mopar ones, but you don't need to
but if you are going to spend the extra money on that, get the good ones from AF/X
http://www.howellautomotive.com/inde...amp;ProdID=652
just remember, anything you do to strengthen the motor mounts will result in more vibration in the interior, esp. if you get a solid bobble strut
Old Jul 26, 2007 | 02:39 AM
boxerjl2's Avatar
boxerjl2
so the Mopar Motor Mount come with bushings??? afX one is more spendy and i trust themopar
but does the front motor mount come with the bolts????
Old Jul 26, 2007 | 09:58 AM
ryleynoyes's Avatar
ryleynoyes
what exactly do you mean by bushings before i answer again?
just to make sure i'm talking about the right part
as far as bolts i would say yes, but... dealership type ****... who knows? when i got my egr valve, i had to buy a gasket seperately, so yea...
Old Jul 26, 2007 | 10:22 AM
boxerjl2's Avatar
boxerjl2
page were located
http://modernperformance.com/dcx/95-...ne-trans.shtml
info on them
http://modernperformance.com/dcx/prothane.shtml
Old Jul 26, 2007 | 03:05 PM
das2123's Avatar
das2123
If you want better motor mounts and not just inserts, get them from Deyeme Racing.
