what engines fit????????
Old Jul 26, 2007 | 03:33 PM
flacoz_da_king's Avatar
flacoz_da_king
Default what engines fit????????
[:@]i dont no what engine i should put in my 98 neon i have piks coming though i jus need a new 1 or do i at all
Old Jul 26, 2007 | 04:33 PM
spudsterier's Avatar
spudsterier
Default RE: what engines fit????????
you have what comming through????
Old Jul 26, 2007 | 07:32 PM
flacoz_da_king
ummm im putting pictures up but i wanna new engine cause i got a sohc 2.0 engine i want more performance
Old Jul 26, 2007 | 10:06 PM
spudsterier
then drop a dohc in it, or beef up the sohc
Old Jul 27, 2007 | 08:42 AM
das2123's Avatar
das2123
Q: What other engines can swap into the 1st gen neon?
A: A 2.4 engine from a 95 to 00 Stratus, 96-00 Caravan, 01 & up PT Cruiser. The SRT-4 engine will swap in also. These are not direct bolt-ins and will require some modification, but they are very doable.
Q: What do I need to get the SRT-4 engine in my 1st gen?
A: You will need the engine, a 2.4 side motor mount adapter, wiring harness, and a NEW PCM that has not seen sentry, unless you are ready to swap the sentry stuff over also. You can eliminate the PCM and run the engine using Megasquirt. Don’t know what that is, Google it!
Old Jul 27, 2007 | 03:50 PM
flacoz_da_king
thinx for all the help both of youl but is it true u can put a impreza motor in im not but i heard ima try 2 get the srt 4 engine
Old Jul 27, 2007 | 04:17 PM
das2123's Avatar
das2123
ORIGINAL: flacoz_da_king
Yes it is true...
https://dodgeforum.com/m_894642/tm.htm
Old Jul 27, 2007 | 05:14 PM
Aerorat's Avatar
Aerorat
Srt 4 engine and trans swap is the way to go
Do a srt4 search on eBay
Old Jul 28, 2007 | 01:56 AM
flacoz_da_king
okay thank you for
flacoz_da_king
the advice
