Tach not working
Old 07-27-2007 | 08:38 PM
fo1fodapo1's Avatar
fo1fodapo1
Default Tach not working
Hi could anyone give me a good reason why my tach does not move at all, i just replaced the engine in my car and the tach did nothing when i started it up, everything is hooked up, i didn't see and wires broken and all the fuses are good, all gauges work but the tach....any ideas???
Old 07-27-2007 | 08:49 PM
NYG's Avatar
NYG
Default RE: Tach not working
Have you ever had any issues with your cluster?
Are you using the sensors off your old engine or the new engine?
Old 07-27-2007 | 11:33 PM
das2123's Avatar
das2123
Tach wire is gray with a blue tracer and run from the PCM. Take a look at it.
Old 07-30-2007 | 10:19 PM
fo1fodapo1's Avatar
fo1fodapo1
i'm using the one that came with the "newer" engine, i don't know if the tach was working before, i got the car from an co-worker for free, is it hard to change it if it is the sensor
Old 07-30-2007 | 10:24 PM
fo1fodapo1's Avatar
fo1fodapo1
i'm going to try that tomorrow, if the sensor is good, and i'm getting power all the way up to the gauge, i'm just going to put in an after market tach somewhere
Quick Reply: Tach not working
