Any way to make IAT sensor read cooler?
Old Jul 30, 2007 | 06:54 AM
Slashwannabe's Avatar
Slashwannabe
Default Any way to make IAT sensor read cooler?
I love the power the car has on a fresh startup in the cooler night air, it would be nice to have this sort of power all the time but theres a problem and its evil and its called the IAT/Map Sensor.
I know you've all heard of the resistor gimmick, I'm wondering if I can place the IAT/map sensor in a different spot so it reads cooler or wire it up to a reliable resistor system? I'm also wondering if on the 96 and newer Neons if a person needs at least 2 resistors for it to work? since its a dual unit that might be the case.
I've heard the PCM over time gets smart to this kind of thing but I'm wondering if I hook it up to a switch so it reads the resistance I want when I need the power for a race or get moving fast sort of situation that using the reistance once in a while the PCM shouldnt catch on you'd think?. Is thereAny way what so ever to fool the sensor into thinking itscooler outside? This is especially a problem when its 90 degrees+ outside.
I have a couple good IAT/Map sensors laying around I wouldnt mind the challenge of taking one apart and seperating them into a seperate unit and wireing them up so they dont conflict with each other whenI attempt this IAT fool job. I would like to know which wires or prongs go to the MAP and IAT.
I'm thinking about getting or making a "Cool Can" if this IAT sensor thing doesnt work out.
http://www.jegs.com/webapp/wcs/store...0002_745113_-1
Thanks guys in advance!
Old Jul 30, 2007 | 08:13 AM
das2123's Avatar
das2123
Default RE: Any way to make IAT sensor read cooler?
I haven't heard of anyone trying something like this, probably because the difference isn't worth the effort.
