srt engine with 1st gen trans
Old Jul 31, 2007 | 03:22 PM
pssssst's Avatar
pssssst
Default srt engine with 1st gen trans
ok... can you or can you not use the first gen trans with the srt4 motor swap? i understand you have to upgrade the clutch but why is every swap ive seen using the srt trans when ive heard you can just use the first gen trans??.... also if you stick to the first gen trans there is no need to flip the trans mount it there????? thanks every1!
Old Jul 31, 2007 | 03:40 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: srt engine with 1st gen trans
you can use the 1st gen. tranny.
Old Jul 31, 2007 | 03:48 PM
pssssst's Avatar
pssssst
what about flipping the trans mount? would i need to do that also???
