Wheel bearing
Old Aug 1, 2007 | 12:58 AM
protivakid's Avatar
protivakid
Default Wheel bearing
So one of my front wheel bearings is starting to make noise and I want to replace it. My only problem is I don't know which one. How expensive are the bearings if I were to just replace both. The only thing I notice is when I turn right the noise stops however straight and left turns the noise is there.
Old Aug 1, 2007 | 07:04 AM
spudsterier's Avatar
spudsterier
Default RE: Wheel bearing
i believe that should mean the drivers side bearing is bad....but i cant remember...
jack up the front of the car and spin the wheels...if the bearing is bad enough, you should be able to hear it when the wheel is turned....
i wouldnt replace both unless you absolutely have to
Old Aug 1, 2007 | 08:45 AM
NYG's Avatar
NYG
If the bearing is that bad
you can just get a firm grab of the tire and wiggle it - if it moves - that is your bad bearing
