LOW RPM PROBLEM THIS TIME WITH VIDEO
Aug 1, 2007 | 10:34 PM
ok ive heard of haveing low rpms becuz the vac line is busted but what and the heck is this problem??
is it safe to drive with the vac line unhooked ??
http://www.youtube.com/watch?v=OKSrts5eylg
Aug 1, 2007 | 10:43 PM
RE: LOW RPM PROBLEM THIS TIME WITH VIDEO
Was it running at low rpms with the vacuum line on or off, I am confused on that part[&:]
Aug 1, 2007 | 10:51 PM
when he had it connect it was idling at 500
when he took it off it went to normal
Aug 1, 2007 | 11:02 PM
Well I have no idea then[&:]
Aug 2, 2007 | 02:06 AM
it will go up with the line off, its letting more air in....
maybe yourthrottle stopper is worn down making it idle low, or the IAC is getting retarded.
Aug 2, 2007 | 02:07 AM
will driveing with this disconected harm my car????
Aug 2, 2007 | 03:10 AM
not really other than it should cause a lean idle and it might want to stall sometimes
Aug 2, 2007 | 03:12 AM
when i had mine off it stalled almost every single time i stopped at a stop light
Aug 2, 2007 | 08:04 AM
hmmm sounds to me like the idle air control motor! CHECK IT with a volt meter =D
Aug 2, 2007 | 12:35 PM
see thats the problem mine does that when it is hooked up,, but i unhoooked it last night and drove around and didnthave any problems at all
not a clue what or were that is
