where can i get a......?
Old Aug 6, 2007 | 12:40 PM
jt46324's Avatar
jt46324
Default where can i get a......?
i need to find a crankshaft pulley, i was changing the timing belt this weekend, and when the pully cqame off it had a small crack in it.
I called dodge and they said it was back-ordered.
I NEED THE NEON BACK, WHAT DO I DO
99' sohc
Old Aug 6, 2007 | 12:46 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: where can i get a......?
Im pretty sure that rrwertz had one for sale, if not im pretty sure advance auto parts has them online for like $48, then you always have ebay.
Old Aug 6, 2007 | 01:17 PM
jt46324's Avatar
jt46324
none on adavnce's website, and how do i find an rrwertz???? i seen some on ebay too, but need it quick
Old Aug 6, 2007 | 01:28 PM
spudsterier's Avatar
spudsterier
where is the small crack at????
i know that most of the pulleys i have seen had a small crack across the spot for the alt. belt....but i think it is just a seam and is supposed to be there
Old Aug 6, 2007 | 03:16 PM
jt46324's Avatar
jt46324
it cracked on the pulley, and also it cracked on the lip the holds the belt on.....
What u think spud.
Old Aug 6, 2007 | 06:16 PM
Jr. Mechanic
http://www.partsamerica.com/ProductL...monic+Balancer
Right there on advance for $42.99
Old Aug 6, 2007 | 06:48 PM
jt46324's Avatar
jt46324
thanx Jr. i just learned its also called a harmonic balancer when i called Napa, apperently noone likes to call it a crankshaft pulley, and the morons at autozone didnt either, they just said not available.
Thnx neon villagers
Old Aug 6, 2007 | 07:19 PM
spudsterier
is there any way you can get me a pic???
Old Aug 6, 2007 | 08:45 PM
jt46324's Avatar
jt46324
hey spud, its cracked, i took it off today and the hairline turned into a CRACK.....by the way, what did u want the pic for???
Old Aug 6, 2007 | 10:41 PM
95neonriceeater's Avatar
95neonriceeater
why don't you just get an under drive pulley since it's already off?
