need some help
Old Aug 6, 2007 | 07:32 PM
kenneth1979's Avatar
kenneth1979
Default need some help
i just finished converting my 1995 neon from auto to manul and now my car wont start and i was wondering if anyone knows what i might have to do to get it to start cuz i had the starter tested and it is good but i still cant figure it out
Old Aug 6, 2007 | 07:34 PM
spudsterier's Avatar
spudsterier
Default RE: need some help
do you have the auto pcm or manual pcm in the car????
did you remove the clutch pedal as well????
Old Aug 6, 2007 | 07:36 PM
kenneth1979
i still have the auto pcm and yes i removed the cluch pedal and put it in my car but i didnt know what to do with the wires on it
Old Aug 6, 2007 | 07:39 PM
spudsterier
if you still have the auto pcm then you need to ground the wires on the plug that connects to the neutral/start switch.....
basically, you cant start your car now because the pcm is getting a reading that your car is in gear.....just like if you were to try and start the car when it was in drive.....
Old Aug 6, 2007 | 07:41 PM
kenneth1979
thanks i am going to try it now
Old Aug 6, 2007 | 07:49 PM
kenneth1979
do you know wich one of the three wires it is
Old Aug 6, 2007 | 08:02 PM
spudsterier
honestly i have no idea.....i think it might be one of the outter wires.....
do you have a haynes manual????
Old Aug 6, 2007 | 08:13 PM
kenneth1979
ya it worked it was the middle one and thanks a lot now i have to take it for a ride again thanks a lot
