fuel pump assembly!!!!
97 SOHC MTX 4dr
the fuel pump assembly has two lines comin out of it, n into a fuel accumalator... I work at Advance Auto Parts, n the cpu list two different versions of fuel pump the one i have n one that has three lines coming out n into a fuel filter, my question is if their is a betterOR worse design n if its interchangable???
1 is probally for a plastic tank and the other for a plastic tank....i believe there are 2 different style pumps availabe for the plastic tanks, but should be interchangable.....the fuel accumulator was only on 95, 96 and 97 neons i believe
