Rear disk ABS
Old Aug 17, 2007 | 04:26 AM
12 volt's Avatar
12 volt
Default Rear disk ABS
today i finished installing rear disk brakes on my 98 sport, the car that i got the brakes form also has ABS . I was wondering if it would be nessisary to install the ABS form theparts caronto my 98?
Old Aug 17, 2007 | 05:28 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Rear disk ABS
no you dont need to
Old Aug 17, 2007 | 07:45 AM
spudsterier's Avatar
spudsterier
ABS sucks anyways
Old Aug 17, 2007 | 08:05 AM
DOHCgarrett t3
yeah ABS is for ppl that dont know how to stop in the snow. even though i like it on my crown vic since its so heavy and it likes to slide a lot in the snow.
Old Aug 17, 2007 | 08:56 AM
das2123's Avatar
das2123
How do you like the look? Any pics?
Old Aug 17, 2007 | 02:58 PM
12 volt's Avatar
12 volt
i really love the look, it almost seems like the rear disk on the neon is bigger that the rears one my BMW E34. Today is going to be the challenge installing the E brake cables thru the little rubbers(any hints). Luckly i figured out a good way of reamoving them with a half inch box end wrench.(When your removing the e brake cables slide the wrench over the cable depressing the three tangs, after that it's pretty easy to pull the cable from the retainers).
i haven't got to take any pics yet because my camera phone has no flash and its way to dark in my garage. ill have to takesome after i finish the rest of the car.The best advie i could give to anyone doing this job is to have a 18mm half inch socket for your impact wrench, makes everything alot easyer.
thax for the help
