neon airbags?
Old Aug 21, 2007 | 09:04 AM
blondiez24's Avatar
blondiez24
Default neon airbags?
I was wondering if the airbags on the steering wheel and dash were interchangable from 95-99? My car is a 95, and I have a person wanting them for a 98. The cars look identical inside, but wanted to make sure. Thanks
Old Aug 21, 2007 | 10:13 AM
das2123's Avatar
das2123
Default RE: neon airbags?
You can't swap a steering wheel airbag into the dash or vice versa, but all 96-99 airbags are swappable. 95's steering wheel airbags are different.
*edited for more clarity*
Old Aug 21, 2007 | 01:09 PM
neoncrazy101's Avatar
neoncrazy101
but u can swap the dash airbag. the only way to swap the steering bag is to swap steering wheels.
Old Aug 21, 2007 | 06:26 PM
blondiez24's Avatar
blondiez24
oh well i took the arbag out of the steering wheel, and I left the steering wheel in it and had the car crushed. oops wish I had known that. So the dash airbag will work in all the dash's from 95-99, andthe air bag in the steering wheel is only 95 unless you swap the wholesteering wheel?
Old Aug 21, 2007 | 06:28 PM
justinsanders's Avatar
justinsanders
since we are on the topic, i have a quick question. i was wating and waitng at a stop sign for a chance to turn. i got mad waiting there for so long so that when i got a chance to go it took it and did so quickly. i peeled out a lil and and had it floored all the way into 3rd gear. when i turned on to the road there was an immediate stop light so i had to stop. as i was slowing down i noticed the airbag light come on. is that ok i was leanin over the center console in case it deployed. and that happened one other time i had just started the car and drove down the road a lil ways and noticed it was on then it soon went off. is that ok what causes that.
Old Aug 21, 2007 | 09:02 PM
spudsterier's Avatar
spudsterier
there is probally a loose connection......
and yes, in order for any other year neon (96-99) to use an airbag from a 95, you would have to swap the steering wheel as well
Old Aug 21, 2007 | 09:40 PM
blondiez24's Avatar
blondiez24
alright thanks for the help guys
