fuel injectors
Aug 23, 2007 | 12:11 AM
fuel injectors
i'm considering a fuel injector upgarde and was wondering if anyone one the forum has experiance with this type of mod.
Aug 23, 2007 | 08:20 AM
RE: fuel injectors
Unless you have a turbo, there is no reason to upgrade your fuel injectors. It WILL NOT add any HP. The stock ones are 19lb injectors and are fine.
Aug 23, 2007 | 09:13 AM
RE: fuel injectors
wat are stock srt4 injectors.... as in pound rating?
Aug 23, 2007 | 10:47 AM
RE: fuel injectors
42
Aug 23, 2007 | 10:59 AM
RE: fuel injectors
dam .. no wonder im running so rich
RE: fuel injectors
how far do you think ill hae to drop the fuel pressure
Aug 24, 2007 | 12:39 AM
RE: fuel injectors
hhumm i would a have figured better atomization and more fuel would do something.
does anyone have experiance with bigger injectors on an neon?
Aug 24, 2007 | 01:10 AM
RE: fuel injectors
i do... i used or rather am stil lusing stock srt4 injectors and it sux. untill i get my regulator on for my turbo it barely idles, and breaks down reall bad in pper rpm's
Aug 24, 2007 | 04:35 AM
RE: fuel injectors
well depends which srt4 injectors
the 04 and 05 have the stage 1 injectors stock
Aug 24, 2007 | 08:35 AM
RE: fuel injectors
i think they are 03 injectors
