2nd gen parts on 1st gen
RE: 2nd gen parts on 1st gen
damn oh well if i get some money maybe ill go buy one for 10 at the yard and see its only ten bucksso yeah id like to use the manifold from a 2nd gen i dont think that will work either. Or i will try it at the yard before i buy it ill try to put it on a 1st gen if it fits ill buy it.
ORIGINAL: spudsterier
as far as i know it wont work
ORIGINAL: catapeed
You will have route the pcv system differently as the second gen hook-up port is mounted on the drivers side of the valve cover just above your cam sensor. ( this can cause your motor to puke oil into the pcv system when making hard right turns) and yes it will bolt directly on. I know because on both second gen motor swaps I have done to 1st gens I always change the 1st gen cover onto the second gen motor.
If you look at all-motors picture you will see it runs into a catch can before going to the pcv valve.
