ECU Questions
Old Aug 27, 2007 | 02:25 PM
teetdogs's Avatar
teetdogs
Default ECU Questions
Ok so i wanna get a new ECU for my 95 highline SOHC ATX what is the best swap for my money? also how diffucult would it be to replace? what all is involved in changing it out?
Old Aug 27, 2007 | 02:27 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: ECU Questions
i've heard that for the atx you can get an af/x ecu
but i think you can use the mopar pcm if you make modifications
Old Aug 27, 2007 | 02:29 PM
teetdogs's Avatar
teetdogs
so mopar doesn't make one for the ATX? where can I get the AF/X ECU i cant seem to find it on google.
Old Aug 27, 2007 | 03:37 PM
das2123's Avatar
das2123
ORIGINAL: teetdogs
They only make one for the MTX. You can use it on an ATX but you either have to add a tranny cooler or hook up a toggle switch to activate your lockup torque converter. If it doesn't engage at freeway speeds it will burn up your tranny.
ORIGINAL: teetdogs
Howell Automotive is the only place that sells them. But buyer beware...they have terrible customer service. Try and look for a used one on ebay. Also you can ONLY use a 95 PCM on your car. They are not interchangeable with other years.
Old Aug 27, 2007 | 03:45 PM
teetdogs's Avatar
teetdogs
Thanks man that is some usefull information, glad I asked instead of possibly burning up my tranny
Edit
When was the last time you saw them on their site? all i see is for the MTX
