I have a 1997 SOHC neon and I was runnin around and it just shut off off on me and wouldn't start after about 10 minutes it started.When it shuts off it acts like it doesnt have a battery
Any help would be greatly appreciated
You could possibly have a bad connection...the easist way to check this would be to locate the ground coming off the starter ...a foot and half up from there the wire should splice off inot two one goin to the starter and another goin to the unibody...make sure that you have a good connection there...if you do ...ill bet you have a problem with your computer ..locate the closes junkyard and see if you can buy a cheap one from them...if money isnt an option get one from your local dodge dealership.. _-kcolwell @ colwell motorsports
My one friend had a dodge charger and his did the same thing and he said it was the barometer sensor do neons have one. and the grounds coming off of my starter they all look ok.
