wont start agian
Old Sep 4, 2007 | 04:56 PM
Chris2121's Avatar
Chris2121
Default wont start agian
sorry for a possible repost
i just changed the headgausket on my car
now it wont start
i checked all the sensors
sounds like it wants to turn over but it doesnt
need help fast
any possible ground might be loose
i know thepass side and the front ground are on and tight
any help please
Old Sep 4, 2007 | 11:08 PM
das2123's Avatar
das2123
Default RE: wont start agian
Double check ALL your connections to the starter. Does it crank at all and not turn over? Have you checked fuses at all?
Old Sep 5, 2007 | 12:45 PM
Chris2121's Avatar
Chris2121
fuses are all good, it was cranking, but now i think the starter went bad from plenty of attempts...i try jumpin it, tryed starting fluid, its getting spark (little flame in the throttle body lol) i dont know what to do, this car never gave me a hard time starting up before, just leaked alot of oil
also even if the starter was bad ( i need to hit it a few times) wouldnt it still start from the extra juice from the jump
it comes close to starting, sometimes i hear a weird quite burble sound from the engine
Old Sep 5, 2007 | 01:42 PM
das2123's Avatar
das2123
You set the timing right? Getting fuel pressure?
Old Sep 5, 2007 | 02:53 PM
Chris2121's Avatar
Chris2121
getting fuel pressure not to sure of the timing, but pretty sure its good (i had to get the head shaved) i made sure everything was tight
Old Sep 5, 2007 | 03:18 PM
RiceBoy_88's Avatar
RiceBoy_88
you might have broke the timing belt.
Old Sep 5, 2007 | 06:03 PM
Chris2121's Avatar
Chris2121
no i can see the belt spin, when someone trys to start it
Old Sep 6, 2007 | 07:37 PM
Chris2121's Avatar
Chris2121
update
swapped out the camshaft sensor with an extra i had, it wasnt it
i have a feeling it may be the crankshaft sensor, it went before, so i put a used one in
if i recall right, that cost about $100-$120 right?
Old Sep 6, 2007 | 10:43 PM
bouda's Avatar
bouda
I'm thinking it's timing.
Old Sep 7, 2007 | 07:32 AM
Chris2121's Avatar
Chris2121
anything else it could be, i think if it WAS the timing, it would still start, but it would either die out or run like crap
