yep. same thing.if you've ever heard someone say they're gonna get something port & polished that means they're gonna bore it and paint it, or clean it.
No it's not the same thing exactly. When you port something, you make it match a gasket or open one end up a little bit. When you bore something, like cylinder walls, then you give it the same diameter all the way through.
And polish does not mean clean or paint. It is a process of making surfaces smooth.
