Removing Oil pan in 95 Neon 2.0
Old Sep 10, 2007 | 10:37 PM
JrWaxdr's Avatar
JrWaxdr
Default Removing Oil pan in 95 Neon 2.0
I was wondering if anyone knew how to remove the oil pan from a 95 neon with the 2.0 SOHC. I can get to all of the bolts but it seems like there is one that is being blocked by the motor mount. I am doing a complete overhaul of my girlfriends car and the oil pan is almost completely rusted through so i just ordered a new one and i cant get the old one off. I appreciate all your guys help.
Old Sep 11, 2007 | 08:14 AM
spudsterier's Avatar
spudsterier
Default RE: Removing Oil pan in 95 Neon 2.0
you need to take that front motor mount bracket off....2 bolts under the motor at the back of the bracket, 2 bolts on top in the front under the starter, and 1 bolt just to the right of the front 2...
its a dumb design
Old Sep 11, 2007 | 10:03 AM
JrWaxdr's Avatar
JrWaxdr
would i need to put a jack under the motor or anything like that while i amremoving those bolts?
Old Sep 11, 2007 | 12:59 PM
das2123's Avatar
das2123
Not necessary when removing but you may need one to install it back on.
Old Dec 10, 2007 | 12:10 AM
thaguamanian's Avatar
thaguamanian
ORIGINAL: spudsterier
its a dumb design
is this the same for a 97 neon dohc? Becuase I attempted to remove the oil pan awhile back but i had no luck. I examined the oil pan and noticed that i couldn't get to one particular bolt because some sort of plate/mount is in the way (same issue with JrWaxdr). Thanks!
Old Dec 10, 2007 | 08:13 AM
das2123's Avatar
das2123
^^^Yes its the same.
Old Jul 17, 2013 | 07:28 AM
BrentBingaman's Avatar
BrentBingaman
any hints on how to get to those 5 bolts that hold the engine bracket on? the two rear ones look easy enough. Do i need to remove the alternator to get to the front ones? its looks like a very tight spot. Thanks
