What is the best neon?
Old Sep 12, 2007 | 12:16 PM
estneon's Avatar
estneon
Default RE: What is the best neon?
do you want it to be streetible or all out drag?
Old Sep 12, 2007 | 12:38 PM
RiceBoy_88's Avatar
RiceBoy_88
I want it to be streetable.
Old Sep 12, 2007 | 01:28 PM
spudsterier's Avatar
spudsterier
ORIGINAL: Aerorat
ORIGINAL: spudsterier
when i was running the srt4 turbo on my stock motor at 8psi i was able to eat stage 1 srt4's all day long....
but everyone needs to note this,
the guy said NO turbo and NO nitrous
I understand that spud and I don't dought it one bit. But did you just slap on a turbo and do that.
you talking about using all the other parts or what????
Old Sep 12, 2007 | 01:32 PM
das2123's Avatar
das2123
95 MTX Sport Coupe with a DOHC motor. Light and has the DOHC motor. With the SOHC engine you are limited to cam changes.
Old Sep 12, 2007 | 02:26 PM
Aerorat's Avatar
Aerorat
ORIGINAL: Aerorat
Slashwannabe said,"Its easier to install a turbo on a SOHC or DOHC and make the power the SRT-4 makes than to spend lots of money on an SRT-4 Engine and then mod and swap."
And the way he is making sound is all you have to do is install a turbo on a 2.0 and it will make the same or more power then the srt 4's 2.4 . And if I am not mistaken you said your red rt set is around 250 horsepower roughly about 30 more +/- a little more than a stock srt 4. Correct me if i am wrong but is that all you did was just slap a srt 4 turbo on or was there more to it.
Old Sep 12, 2007 | 02:32 PM
estneon's Avatar
estneon
he red r/t is 350 hpmaby even more
Old Sep 12, 2007 | 02:56 PM
mmench's Avatar
mmench
you gota do a few small fuel mods like a rrfpr and return line but basically you just gota tune it once its on. dazzler got 269whp i beleive on a sohc motor ( correct me if im wrong) with a basically stock motor. im in the middle of the srt swap as we speak to my stock 98 r/t
das2123's Avatar
das2123
ORIGINAL: estneon
Thats with his built engine though. When spud first put the SRT-4 turbo on, the engine was all stock.
Old Sep 12, 2007 | 04:08 PM
Aerorat's Avatar
Aerorat
ORIGINAL: estneon
Not on stock internals
Old Sep 12, 2007 | 04:31 PM
RiceBoy_88's Avatar
RiceBoy_88
So get the 95sport coupe with the dohc motor that would be the best way to go?
