grinding sound when turning left.
Old Sep 13, 2007 | 12:38 AM
tattoojack's Avatar
tattoojack
Default grinding sound when turning left.
only happens on acceleration and as soon as the wheel is turned left of center. coming from the wheel area on the driver side. could it be tie rods or hub bearings? or whatelse?
Old Sep 13, 2007 | 01:01 AM
Captansavaho's Avatar
Captansavaho
Default RE: grinding sound when turning left.
i get that sound to is it like a really hard scrap? expet when i turn right almost as if something was digging into the inside of the rim,
Old Sep 13, 2007 | 01:40 AM
tattoojack's Avatar
tattoojack
it sounds like an rc car revin up in my rim. but only when turnin left, accelerating, and at a low speed. just a grinding sound, kinda low but definately noticeable.
Old Sep 13, 2007 | 08:35 AM
Aerorat's Avatar
Aerorat
Raise the car up. Put on jack stands. Grab tire at 12:00 o'clock and the 6:00 o'clock. Push in the top of the tire and pull out on the bottom. If it moves it is the bearings. Do this to both sides
Old Sep 13, 2007 | 09:12 AM
boxerjl2's Avatar
boxerjl2
i was thinking maybe one of the side motor mounts??? but dont know if thats possible
Old Sep 13, 2007 | 01:45 PM
12 volt's Avatar
12 volt
im thinking wheel bearing
Old Sep 13, 2007 | 01:53 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Wheel bearing, tire rub (what size tires do you have?), or cv joint.
Old Sep 13, 2007 | 04:30 PM
tattoojack's Avatar
tattoojack
i really think its the bearings. it happens as soon as the wheel is turned left any at all. and only when accelerating. if in nuetral, no noise. so now i am worried it may be something with the drive shaft.
oh and the tires are stock, so no rub.
Old Sep 13, 2007 | 06:53 PM
Aerorat's Avatar
Aerorat
i have got two steering nuckels with bearings in them and two drive shafts make me an offer plus shipping and handling
Old Sep 14, 2007 | 02:12 PM
tattoojack's Avatar
tattoojack
do the drive shafts come with the wheel bearings?
