Spitting and Sputtering
Old Oct 12, 2007 | 07:51 PM
RiceBoy_88's Avatar
RiceBoy_88
Default RE: Spitting and Sputtering
Ya dude go with das had the same problem and he told me it might be the o2 sensor and it was the downstream one.Thats what I would do first.
Old Oct 14, 2007 | 09:38 PM
manny610's Avatar
manny610
i hadthe same problem i change my spark plug wires and the coil and it went away i got msd
Old Oct 23, 2007 | 08:37 AM
NeonCaleb's Avatar
NeonCaleb
Okay...so I put a fuel pressure gauge/regulator (just wanted the gauge part of it) on the car and I'm running 49 psi even with a leak from the regulator hoses. So we have eliminated the fuel pump...unless of course it is losing voltage while I'm driving. My next step is going to be the catalytic convertor. What would happen if I just gutted out the converter on the car (no emissions laws here in Nova Scotia)? Also, what would happen if I switched the o2 sensors (wire the rear one to the front and vise versa)?
Old Oct 23, 2007 | 09:20 AM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: NeonCaleb
Update:
Today i took my brother for a drive and the car worked great and then all of a sudden it started to really loose power,
Loose Power? You mean "Lose Power" I don't understand.............
Old Oct 23, 2007 | 03:47 PM
teetdogs's Avatar
teetdogs
I am having the exact same problem. Let me know if you get it resolved cause I would like to get it fixed as well.
Old Oct 23, 2007 | 11:03 PM
jimustanguitar's Avatar
jimustanguitar
i have the same problem too, but have not changed my o2 sensor yet either. are there really two of them in these vehicles? i have a 96 with a SOHC 2.0. Thanks
Old Oct 23, 2007 | 11:07 PM
das2123's Avatar
das2123
ORIGINAL: jimustanguitar
Yes you have 2. One upstream (on the exhaust manifold) and the downstream (just after the cat converter).
Old Nov 7, 2007 | 10:24 PM
dtecneon's Avatar
dtecneon
make sure its not your Vacum line . Ive had this happen too me and it was my vacum line . make sure your tubes are not rotting away , because mine were and i went to autozone got some tubes and fixed it in a hour and worked GREAT . My o2 senior is off and i need a new one but it dont mean its that. Check your vacum line.
Thanks.
cody.
