door panel trouble HELP!!!!!!!!!!!!!!
Old Sep 15, 2007 | 07:54 PM
flacoz_da_king's Avatar
flacoz_da_king
Default door panel trouble HELP!!!!!!!!!!!!!!
very agervating i bought new speekers for my neon and i got most of it off but i have manual windows and i do not no how too get the window roller thingy off adiagram will help or if well explained i will understand plese help
Old Sep 15, 2007 | 08:51 PM
das2123's Avatar
das2123
Default RE: door panel trouble HELP!!!!!!!!!!!!!!
There is a small horseshoe looking retainer clip that holds it on. You can buy the $5 tool that takes them off easily or try popping it off with a small screwdriver. But don't LOSE IT. You can also try using a towel or something and stick it behind there and work it back and forth until it comes off (I have heard of doing this, but never tried it).
Old Sep 15, 2007 | 09:19 PM
NEONRT98's Avatar
NEONRT98
I usually take a paperclip, unbend it, and put a SMALL hook at the end with a pair of needle nose pliers.. that usually does the trick! To get it back on, just put it back on the crank handle and push it back on.. might need a light tap with a hammer
Old Sep 15, 2007 | 09:25 PM
spudsterier's Avatar
spudsterier
ORIGINAL: das2123
works awsome....its the only way ive ever done it
Old Sep 16, 2007 | 12:16 AM
tattoojack's Avatar
tattoojack
dude a shop towel or hand rag works great. skip the tool. this method, if you start the rag behind the handle and go up towards the hub, sends the handle flyin off in an instant. and the lil pin will stay right in the handle. you just gotta make sure you look to see where the lil ring that goes behind the handle flies off to.
Old Sep 16, 2007 | 09:11 AM
Jr. Mechanic's Avatar
Jr. Mechanic
I used a towel the first time like the haynes manual says to do, but the second time I tried to use it it didnt work[&:]
Old Sep 16, 2007 | 02:21 PM
tattoojack's Avatar
tattoojack
you gotta turn the handle where its pointing straight down (6 o'clock). grab the rag by two corners, one in each hand and put it under the handle going up towards 12o'clockslide the rag left to right with upwards pressure. it'll pop every time.
Old Sep 16, 2007 | 04:34 PM
flacoz_da_king
ok people thanks i got them off BUTT i lost both the little lock things[>:] lol ima go buy some do they have them at autozone[8D]
Old Sep 16, 2007 | 05:24 PM
Jr. Mechanic
ORIGINAL: das2123
Mhm.
Old Sep 16, 2007 | 05:27 PM
flacoz_da_king
thanx
