dohc ecu vs. sohc ecu
Old Sep 17, 2007 | 01:08 AM
dirt_trac_racer_80jr's Avatar
Default RE: dohc ecu vs. sohc ecu
what do you mean mulletman...i can take the stock injectors from a 5.0 mustang and use the neon fuel rail...wat about the plugs ...i cant imagine they are the same...have you done this?[sm=WTFsgign.gif]
Old Sep 17, 2007 | 01:12 AM
mulletman11's Avatar
mulletman11
yea the stock neon injectors can be simply switched with the mustang stock 5.0 injectors, if u wanna run richer fuel then do that. wta plugs are u talking about?
Old Sep 17, 2007 | 01:15 AM
the electronic plugs that are on the top of theinjectors ....that run the firing order...would i have to switch them out with the plugs of a 5.0
Old Sep 17, 2007 | 01:19 AM
mulletman11
no they fit right on i belive, ive done it
and the distrbuter runs the firing order
not the plug caps
Old Sep 17, 2007 | 01:26 AM
ok ill have to look into it...what did you mean by direct plecment...wats thats
Old Sep 17, 2007 | 08:22 AM
das2123's Avatar
das2123
You can use 05 and up injectors from a Mustang GT which has the 4.7L engine in it, not the 5.0! They swap right in because they use the EV6 connector. You can unplug your stock neon injectors and pop in the stock Mustang GT 24 lb. injectors.
Old Sep 17, 2007 | 05:52 PM
mulletman11
my apologizes das
i could have sworn i got mine fomr a 50
srry
Old Sep 17, 2007 | 05:53 PM
420a_Jon's Avatar
420a_Jon
what kind of gain do u get by swaping ur injectors? would it do anything for an almost stock DOHC neon with just an intake?
Old Sep 17, 2007 | 10:45 PM
did the 4.7 injectors help much ....i think the ones i have in now are either 21lbs os 19 lbs..not sure which
Old Sep 17, 2007 | 11:20 PM
das2123's Avatar
das2123
ORIGINAL: 420a_Jon
The only gain you will see by swapping injectors is an increase in gas consumption. It does not add HP AT ALL!
