More or Less back pressure
Old Sep 16, 2007 | 10:36 PM
dirt_trac_racer_80jr's Avatar
Default More or Less back pressure
this is my first year racing 4cylinders ive always been a v8 kinda guy ...so when i started making my car i thought about punching out the cat and shortin up the pipe for more flow...like you would for a v8...i was told that a 4 clyinder needs back pressure to run right and punching out the cat kills the power..any truth to this...
Old Sep 16, 2007 | 11:01 PM
jfink's Avatar
jfink
Default RE: More or Less back pressure
from what i heard you don't lose power right off but down the road you could have problems with performance. but this is just what i heard don't know if its true or not.
Old Sep 16, 2007 | 11:09 PM
95to96transplantneon's Avatar
Neons do need some backpressure, not as much as Honda's but as long as you have a muffler even a high flow you should have enuf backpressure. However you can run straight pipe and have no side affects other then being deaf an hour later.
Old Sep 16, 2007 | 11:17 PM
mulletman11's Avatar
mulletman11
the neons have more than enough back pressure if u knock out the cat and leave the pping the same
Old Sep 16, 2007 | 11:20 PM
jfink's Avatar
jfink
what if you replace the whole exhaust from headers to muffler leaving out the cat??
Old Sep 16, 2007 | 11:41 PM
mulletman11
ok
just make some twists and turs, staright back is gonna rob u for back pressure
eliminating the cat is fine
get 4-2-1 headers and go piping all back but dont make it straight throw some curves to give it pressure. itll sound mean and work fine.
Old Sep 17, 2007 | 12:40 AM
i wanna bring the pipe out right behind the drivers door.the pipe would look like a backwards L...do you think this would make enof back pressure or should a run a cat.. its a racecar i dont care how loud it is im lookin for performance.
Old Sep 17, 2007 | 12:58 AM
mulletman11
then if ur looking for performance dont cut it at the door, let it run 4.2.1 headers and go no cat just standrd neon piping, like u hollowed out the cat
Old Sep 17, 2007 | 01:02 AM
because of the afco springs the car sits alot lower than a stock neon ....i figured that the less pipe i have under the car the less hance there is that it will get ripped off ...if i run the L with a cat is that enof back pressure
Old Sep 17, 2007 | 01:07 AM
mulletman11
i dont think so
but ive never heard of anyone doing that
i think no
ask das in the mornign hell no
