View Poll Results: A poll
neon sxt
0
0%
neon DOHC
40.00%
other...which motor....
20.00%
Voters: 10. You may not vote on this poll
motor....
Old Sep 26, 2007 | 01:46 PM
  #31
Aerorat's Avatar
Aerorat
Default RE: motor....
If I can have the car after it blows the pistons through the oil pan I will do it
Old Sep 26, 2007 | 05:07 PM
  #32
Slashwannabe's Avatar
Slashwannabe
I'm gonna use the Turbo mostly for low end *****, I've talked to some people at Hahn and they said I should be fine with 7psi of boost on a stock SOHC especially since I'm using the DOHC pcm which gives a little more advance and fuel.
Hahn uses Mitsubishi Turbos which generate quite a bit of heat compared to other designs like Garrett but they spool really fast which is nice : ) but aslo the extra heatgives your engine a better chanceof getting sparkknock.
I've allready planned that incase I get spark knock I will first use Acetone (they recomend 3-4 ounce per 12 gallons of gas) this will eliminate spark knock while cooling the combustion chamber down quite a bit. My brother used this for years in his 1969 Camero drag/street car with 13:1 compression to eliminate knock and clear up high punch. Pretty much the 110 octane race gas wasnt enough for his 13-1 compression, but 87 gas mixed with a few ounces of Acetone they say gives an octane rating of 125+, not to mention you get 5-10miles ormore per gallon depending on applications. The only time my Neon has got more than 310 miles on a tank was when I was using a mix of 87 andAcetone.
I kinda wanted to wait on the intercooler because they recomend intercoolers after 10psi because of lag and severe heat after 10 psi so I'll wait to see how the 7psi goes.
Old Sep 26, 2007 | 05:45 PM
  #33
Aerorat's Avatar
Aerorat
ORIGINAL: Slashwannabe
yeah 2500 Rpm on mine is when it grows ***** as well, when I replaced my Timing belt and put it all back together it had major ***** for 3 days, now it kinda has gotten slower off the line its not the worst right now but I'm not exactly asconfident in aoff the line raceas I was when it was running so good last week.
So right now I'm wondering what causes the change in off the line power as the 2500Rpm+ range is always consistant no matter the weather.
So you are going to put a turbo on a motor that is doing what you stated above good luck
Old Sep 26, 2007 | 10:51 PM
  #34
neoncrazy101's Avatar
neoncrazy101
ORIGINAL: sxybrod
why would the title say 1994 on it instead of 1995? i know stupid question worth lookng into more tho
or could be a very early 94 build like my red 4 door. its a March 94 build and according to the vin it was the 8,066th Neon to be built.
Old Sep 26, 2007 | 11:03 PM
  #35
dirt_track238's Avatar
dirt_track238
i have a sohc mtx. what kind of dohc computer should i put in to make it better? i already have a mopar sohc mtx pcm
Old Sep 26, 2007 | 11:44 PM
  #36
neoncrazy101
ORIGINAL: dirt_track238
the Mopar Performance is fine. if you want to step it up theres the Af/x from Howard. but expect to wait a lonnnng time. and dont put in a DOHC pcm unless u have a DOHC.
Old Sep 26, 2007 | 11:51 PM
  #37
spudsterier's Avatar
spudsterier
ORIGINAL: neoncrazy101
you mean HOWELL dont you?????
Old Sep 27, 2007 | 05:01 AM
  #38
estneon's Avatar
estneon
hey slash advanced timing is Bad for turbos...i would wait for the ic...you say the mistsubishi turbosgive off a lotof heat but try any turbo with out a iceven at 7psi
Old Sep 27, 2007 | 08:19 AM
  #39
das2123's Avatar
das2123
Will be waiting for the "my engine blew up" thread by slashwannabe soon.
Old Sep 27, 2007 | 08:40 AM
  #40
spudsterier
ORIGINAL: das2123
me too
