timing and hp
Old Sep 27, 2007 | 05:41 PM
rt98neon's Avatar
rt98neon
Default timing and hp
does anyone know what the best timing would be for max top end hp
Old Sep 27, 2007 | 07:06 PM
justinsanders's Avatar
justinsanders
Default RE: timing and hp
pretty sure just your regular goodyear belt. and it would be a good idea to get a walbro water pump at the same time and notice some hp restoration.
Old Sep 27, 2007 | 11:08 PM
12 volt's Avatar
12 volt
ORIGINAL: rt98neon
the best thing you could do is use the factory timing settings.
only way your going to know what the best cam setting is if youhave a dyno
