Neon stalls no ck/engine light NEED HELP!!!
Old Sep 27, 2007 | 10:54 PM
ultima4700's Avatar
ultima4700
Default Neon stalls no ck/engine light NEED HELP!!!
Ok so here it is I’ve been reading all the forms learned a lot about the neon just picked up a 95 SOHC Auto w/118,000 miles but I’m stomped. In the past 10 days I put in 1400.00 in work in to it cant figure out what’s wrong. For the problem, The car stalls out when parked when driving when stopped the ck/engine light will not be on when staled the car will not start until the light comes back on I have to give it about 1-2 min for the light and then starts up just to stall agene down the road. Now for the parts the shop installed.
Crank sensor
New relays
Speed sensor
Oil pressure switch
Radiator
Plugs
Wires
Coil
Front breaks
Had the ac charged
Fuel filter
PCV Valve
Valve cover gasket
New seal on cam sensor
Thermostat
Oil change
Trans flush
Fuel Sys cleaner
Fixed some of the melted wiring harness
It had a new starter & Battery
I know most of the parts I have listed doesn’t have much to do with my issue but just wanted to explain what I dun to it. The mechanic tolled me that its not the fuel pump that the fuel pump would not cut out the ck/engine light. He doesn’t know what to do next so HELP Thanks
Old Sep 28, 2007 | 09:57 AM
ultima4700's Avatar
ultima4700
Default RE: Neon stalls no ck/engine light NEED HELP!!!
Well I guess all of you know as much as me thanks any way
Old Sep 28, 2007 | 01:43 PM
12 volt's Avatar
12 volt
map sensor?
Old Sep 28, 2007 | 06:02 PM
bone33's Avatar
bone33
i'll give you $100 for the car.
Old Sep 28, 2007 | 08:39 PM
ultima4700's Avatar
ultima4700
I can drive it to the junk yard and get 275. befor that I will part it out
Old Sep 29, 2007 | 03:08 PM
ultima4700's Avatar
ultima4700
[sm=happy046.gif]Fixed it keep your 100.00 [sm=smarty.gif]
Old Sep 29, 2007 | 04:05 PM
12 volt's Avatar
12 volt
what did you do?
